Cooling down the turbo: I still don't get it :(
I do it every time (ok, almost every time), but I always sit there for a minute asking myself what sense it all makes. One can get pretty existential in an idling car :-)
If you've got a 225, it shouldn't matter since we have some kinda pump that keeps the oil moving long enough to keep it from cooking in the turbo, but I still do it anyways just for peace of mind...Better to waste a minute here and there than to spend a whole bunch of money for a new turbo one of these days, right?
I welcome comments on my ideas on this topic but I think it makes sense to drive longer rather than idle. The added bonus is that you drive more :-)
There is STILL some risk of this...letting the car idle (recommendation is for about 2 minutes) significantly cools the entire assembly WHILE it's being lubricated (one of the main functions of lubrication IS cooling, taking the hot oil away and replacing it with cool oil cools the turbo). The turbo temp is much lower and the chance of coking the oil is virtually eliminated.
It's one of those things that CAN'T hurt...but you MAY never need it. Good rule of thumb is that if the last couple of minutes of your drive are mild and gentle, this probably has the same effect. If you have been romping on it through the canyons for the last two hours...you SHOULD be doing a cool-down for 2 minutes. It's actually in the manual.
Hope that helps.
