Rear Zimmermann Install, with Porterfield Pads
Old Mar 28, 2002 | 03:50 PM
JustJeff's Avatar
Default Rear Zimmermann Install, with Porterfield Pads
I ordered a pair of Rear Zimmermann Rotors, from Jose Rotger at LR Engineering. They came today.
Here are the part numbers and the price.
Zimmermann Rear rotors P/N-8L0615601ZD For TTQ 225 rear, vented) $155.86 set
<img src="http://home.attbi.com/~jbipes/jpgs/box.jpg">
Here they are, cleaned of the shipping oil, and dried.
For more details of some of the following process, see my Front Zimmerman Install on my site.
<img src="http://home.attbi.com/~jbipes/jpgs/rotors.jpg">
I started by removing the wheel, natch, and trying to do a little clean-up. It
was 50 degrees today, and the garage was fine for this.
<img src="http://home.attbi.com/~jbipes/jpgs/before.jpg">
The rotor set screws came out remarkably easy. I removed the caliper, pad,
and caliper bracket. One thing that makes this install a lot easier now, is to
modify a simple wrench. You need a 15mm open end, and a 13mm to remove
the caliper. You need to hold the 15mm nut on the inside of the bracket, and
turn the 13mm on the outside. The distance between the bracket and a metal
spacer on the 15mm side is just a bit too narrow, to allow a std. 15mm wrench
to fit properly. I tried this with 2. I solved this by buying the cheapest 15mm
wrench I could find, made in that large Asian country, and right, deployed
the belt sander. It now fits properly, and I can hold the 15mm side and
tighten the outside without compression of the 15mm side.
<img src="http://home.attbi.com/~jbipes/jpgs/15mm.jpg">
Once the caliper is removed, suspend it using a coat hanger wire, on another
part of the suspension. This will allow you to get at the caliper bracket. The
pic here shows the bracket mounted on the new rotor, but it also shows
where the socket head cap screws are. You will need a 8mm Allen wrench to get
this bracket out. These were tight!
<img src="http://home.attbi.com/~jbipes/jpgs/caliper.jpg">
Remove the screw on the old rotor hub. This came out easy. I needed to use
a hammer to break both rotors loose. I used a wire brush wheel on a drill
motor, to get rid of the rust. I cleaned off the rotors with carb cleaner, dried
them, and mounted them on the hub. Also, on the cylinder in the caliper, you
can see where I added new Disk Quiet/glue on the surface. I added this to
the pads also.
<img src="http://home.attbi.com/~jbipes/jpgs/inplace.jpg">
I re-installed the caliper bracket. I put the pads in place on the new rotors,
fitting them into the slots on the caliper bracket. Then I slipped the caliper
over the pads, replaced the screws, and the job is done.
<img src="http://home.attbi.com/~jbipes/jpgs/caliper2.jpg">
<img src="http://home.attbi.com/~jbipes/jpgs/completed.jpg">
I drove on them a bit, and they are bedding in nicely, thank you.<ul><li><a href="http://www.porttuning.com/specials.htm">LR Engineering</a></li></ul>
Old Mar 28, 2002 | 03:59 PM
JustJeff's Avatar
Yea, clean, quick. UPS Tracking, the works.
Old Mar 28, 2002 | 04:05 PM
SteveTT's Avatar
He is a good source, Glad I looked.. Did he treat you well??
Old Mar 28, 2002 | 05:02 PM
Absolut Todd's Avatar
Junior Member
Welcome to the club Jeff! Great DIY mod.
Old Mar 28, 2002 | 05:11 PM
MichaelTT's Avatar
Senior Member
Very cool...great choice and enjoy... :-)))
Old Mar 28, 2002 | 06:54 PM
HACK THS's Avatar
What size will fit the 180 front and back?
Old Mar 28, 2002 | 07:20 PM
JustJeff's Avatar
Default this
Zimmermann front rotors P/N-8L0615301ZD
(For 180/225 Quattro) $142.86 set
Zimmermann Rear rotors P/n-1J0615601CZD
(For 180 rear, solid) $110.00 set
(For 225 rear, vented) $155.86 set
Old Mar 29, 2002 | 04:28 AM
seaTTym's Avatar
Member
Default Looks great!...drill pattern is different, I wonder if mine are really zimmermans...
<center><img src="http://pictureposter.audiworld.com/12894/rear-rotors.jpg"></center><p>Did you happen to check if the venting vanes were directional in the set you received?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 29, 2002 | 06:16 AM
JustJeff's Avatar
Default Mine are sorta "omni-directional"...
Looks like they could go either way.
I did not check the venting vanes, I will
Brozee
36
Aug 28, 2013 12:32 PM
Krisko
Apr 12, 2003 06:36 AM
plug1
May 23, 2002 06:47 AM
bmwslayer
12
Oct 13, 2001 07:16 AM
