Can anyone tell me if this is normal for a chip 225TT?
Old Mar 29, 2002 | 10:15 AM
225TTQ's Avatar
Default Can anyone tell me if this is normal for a chip 225TT?
<center><img src="http://pictureposter.audiworld.com/15662/dsc00018.jpg"></center><p>I've ask this couple days ago, but most answer were form 180 owner, I just install mt boost guage, the 1st and 2nd gear peak about 18psi and hold 15psi, 3rd gear peak at 23 and hold at 20psi. 5th and 6th peak 25psi+ (cuz my guage only display up to 25psi) and hold at 23-24psi
Is this normal for chipped 225TT? I'm running upsolute chip and I think I'm the only one in this borad. Anyone can answer me with GICA, APR, MTM?
Old Mar 29, 2002 | 10:24 AM
Jason Chen's Avatar
Default Hm.............
<center><img src="http://pictureposter.audiworld.com/4297/cantsee.jpg"></center><p>
Old Mar 29, 2002 | 10:32 AM
dallasTTQR's Avatar
Junior Member
I'm not the expert on the turbo but I don't think its capable of producion 25 PSI
Old Mar 29, 2002 | 10:35 AM
Duffer's Avatar
Member
And you purchased that chip --Why?
Old Mar 29, 2002 | 10:36 AM
SBTT's Avatar
Junior Member
But ,Officer!!!...I was just trying to get a picture of my boost guage!...Lane? What Lane?: )
Old Mar 29, 2002 | 10:41 AM
Lightweight-USPowah's Avatar
Where did you tap your hoses into?
Old Mar 29, 2002 | 10:48 AM
PanTTher's Avatar
Default Your gauge is most likely not calibrated right. But if it is...
and the turbo is generating the high pressure you're seeing you can be sure it will not last very long. It will grenade itself.
Old Mar 29, 2002 | 10:50 AM
PhilMason's Avatar
Default If you can't see the guage . . .
<center><img src="http://pictureposter.audiworld.com/4405/dsc00018_2.jpg"></center><p>
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 29, 2002 | 11:00 AM
Can't he check the readings with a Vag??
Old Mar 29, 2002 | 11:05 AM
TRM's Avatar
TRM
Default what's the gauge read when at idle?
it should be reading somewhere around 20-22 in Hg... if it's not, i.e., only reading 8-10 in Hg - that's a good sign your gauge is FUBAR.
