Epileptic Instrument Panel, Then Meltdown
Old Jun 23, 2002 | 05:57 AM
spi9959's Avatar
New Member
Default Epileptic Instrument Panel, Then Meltdown
Well, after only 3800 miles on the odometer, my 2002 180 had to be towed to the dealer. For the past week, in the mornings on starting the car, the instrument panel read-outs including speedo and tach were going crazy ... lights flashing and tach and speedo needles all over the place. After driving for a while, all would go back to normal. Last night, I couldn't get the car started. Actually, it would start and immediately die out like it wasn't getting any spark or fuel. Plus, the instrument panel lights remained on even though the car was off and the key out of the ignition. Weird! I really hope that this isn't a sign of things to come.
Old Jun 23, 2002 | 06:23 AM
?lueshirt's Avatar
Senior Member
Are you chipped?
Old Jun 23, 2002 | 06:39 AM
spi9959's Avatar
New Member
Default Re: Are you chipped?
Nope---no engine mods at all
Old Jun 23, 2002 | 10:58 AM
?lueshirt's Avatar
Senior Member
Default Hmmm
The exact thing happened to me. Turned out to be a bad solder joint between the chip and the ECU. Could possible be the same thing with yours, but the odds would increase if you had an aftermarket chip solder in.
Old Jun 23, 2002 | 04:44 PM
XTTASY's Avatar
Default Something as simple as a loose battery cable can do this. ...
a poor connection can cause very erratic voltage to the instrument cluster, ECU etc causing these kinds of things. I 've seen this before, not on a TT, but definitely woth checking...
edward TTR
Apr 18, 2005 09:12 AM
superXracing
11
Feb 24, 2003 02:40 PM
RawleP
Mar 21, 2001 06:59 PM
ChuckH
Aug 4, 2000 08:43 PM
Tom
Dec 8, 1999 06:06 PM
