AWE Group Buy.......
Old Jun 24, 2002 | 08:30 AM
ZeroCaviTTy's Avatar
Default AWE Group Buy.......
I got the H&R/Bilstein combo.
Now I am looking for the Kmac camber adjusting kit.
Anyone selling ????
Old Jun 24, 2002 | 08:36 AM
Lightweight-USPowah's Avatar
agh dammit, thats right.. Humm, should I go kmac or forge? Hottub?
Old Jun 24, 2002 | 08:40 AM
Larrytt's Avatar
Elder Member
Default John, makes no difference except in your wallet . . .
You can also try what KW claims will work and that is swapping the upper and lower control arms to get the camber back into spec . . . but I don't know of anyone doing that.
The KMAC works just fine, not need to replace the entire control arm.
Old Jun 24, 2002 | 08:42 AM
You know if we will ever see an alumin control arm? Is forges setup any lighter?
Old Jun 24, 2002 | 08:46 AM
Larrytt's Avatar
Elder Member
Default I don't know what the Forge control arm is.
The Griffin has to be heavier since they take a stock arm and weld on adjustability to it, so they are adding weight.
How did Saturday go?
Old Jun 24, 2002 | 08:47 AM
Default Oh larry, I also figured out a new way to make molds of the car..
Really cool.. I actually stumbled upon this last night.. Id only do this with the west system epoxy though because it has no oder.. Since the epoxy dries in about 3 hours (dries but does not harden so its like a very thin rubber- very flexible) you can lay down some plastic in the area you want the mold, then you put the mold over the plastic and put something heavy over the fiberglass and let it dry.. This eliminates the chances of dripping epoxy in the interior and also eliminates the need to make a mold of the dash..
Old Jun 24, 2002 | 08:49 AM
Larrytt's Avatar
Elder Member
Default one more thing . . . for the money you might spend on new control arms
with some adjustment in them, there is no reason for Griffin and possibly Forge (but I don't know) to ask for your old control arms as a core charge! That to me sucks. For what they are doing to the arms, they should head to a dealer and purchase new arms and sell them modified not require your old arms to then pass them on to the next person! I don't like that at all. But check with Forge to see if they use new arms, build something from scratch or require your old arms in trade.
Old Jun 24, 2002 | 08:50 AM
Default saturday went pretty good..
No problems.. thanks again for all your help.. Removing the filter was a pain because the Intercooler pipe is right in the way .. That took the longest.. Other then that, everything was fine..
 Pouria Savadkouei
 Michael S. Palmer
Larrytt's Avatar
Elder Member
sound interesting, but would make it hard to make copies, right?
Old Jun 24, 2002 | 08:51 AM
Larrytt's Avatar
Elder Member
I couldn't believe the question Doug called me with though! lol I couldn't stop laffing
