Bilstein Shock/Neuspeed 19mm rear bar part numbers for a 2001 TTQ? Denver/Boulder area installers?
Do I need to specify any special parts or just email them and ask for pricing for the parts for a 2001 TTQ? And is the current advice when staying with stock springs Bilstein Sports or HDs? (I seem to remember Sports being a better match for the stock springs but I don't recall understanding the exact technical reason why.)
Also, do any Denver/Boulder area TTers know of a good shop to do the install (and that won't be all upset because I didn't buy parts from <i>them</i>)?
If this is true, perhaps I will just go with the shocks for now; I know not to lift or brake in a curve but have been known to let my mind drift a bit on the occasional on-ramp and have had to brake in a curve with no ill effects with the stock suspension; if I wanted to spin instead I <b>would</b> buy the S2000. :-)
You can play with tire pressue, but only so much. The adjustable coilovers allows you to dial in and dial out the oversteer.
The shocks are a good start. Don't quite fathom you reluctence to do the spring, IMNSHO stock TT's look like 4x4's and hanlde as such. You want handling, you need lower center of gravity.
Good luck
Lowering the car any would just be <i>asking</i> for body/undercarriage damage, thus my aversion to lowering; I already have to slow down to about 10 MPH to avoid bottoming the nose out on the road in front of drainage channels (where each road leaves the intersection) in the developments around the business park where I work...
I don't know you, in fact this is probably the first time I have responded to one of your post, and quite frankly, probably the last.
A bunch of people have made suggestions and tried to help and you just contradicted every point made. These are people that have done the modifications, documented it, posted about, and discussed it to death. Then you post out of the blue that the handling is sub-par.
You want better handling, but don't want to lower it. You want to reduce the understeer, but don't want the rear to come around.
You THINK you want a sports car, but based on your posts, you really don't.
