Sound like a DV issue?
Old Jun 25, 2002 | 08:09 AM
brickz_TT's Avatar
New Member
Default Sound like a DV issue?
I notice that while pulling off the line, I get very little thrust until I hit about 2500 RPM's. Is this typical? It seems like it's gotten worse since I got the car.
FYI, I have the OEM DV in a 2000 180C.
Joe
Old Jun 25, 2002 | 08:12 AM
Larrytt's Avatar
Elder Member
Default So you are not feeling the boost kick in until 2,500?
Could be any number of things, one of which could be the DV. Are you feeling lots of boost once you get to 2,500 and beyond? About when does the boost drop off? Is it at least sticking around to 5,500? How is it in other gears? If you get into second and let the car idle down to around 1,200 rpm and punch it, when does boost kick in?
Old Jun 25, 2002 | 08:19 AM
brickz_TT's Avatar
New Member
Default Yes Larry..
When I get to the point where the boost kicks in (around 2500), it's enough to throw my head back.
I can check on the 2nd gear to see at what RPM the boost kicks in. But I do know that if I slow down at a "Stop" sign, while not quite stopping, and I pull out in second, the boost isn't there right away.
Thoughts?
Joe
Old Jun 25, 2002 | 10:27 AM
MaxHedrm's Avatar
Default That is the way my 225 behaves, I don't get much til almost 3.5k in any gear.
Larry, does the turbo in the 180 spool up that much faster?
Old Jun 25, 2002 | 10:46 AM
Abel-TT's Avatar
Junior Member
Default 3500k in my 180 seems to be it's sweet spot, get some kick before, but 3500 is the magic number.
I'm running stock with stock dv.
Old Jun 25, 2002 | 11:53 AM
jailbird's Avatar
Isn't that normal?
Old Jun 26, 2002 | 02:40 AM
brickz_TT's Avatar
New Member
Default I dunno...
this is my first stick car.
Hell, I used to drive a piece of crap, and starting off the line from an idle, it was probably faster.
SpyderSE2(movie man)
Jul 22, 2007 01:53 PM
maaliish
Sep 9, 2005 06:59 AM
EricBss7_CT
Aug 16, 2004 07:39 AM
A4psi
Jan 10, 2004 08:11 AM
zapco98
14
Jun 19, 2002 08:07 PM
