Installing a new Changer
Old Aug 23, 2002 | 08:25 AM
CharlieC's Avatar
New Member
Default Installing a new Changer
Hey Folks,
I'm looking at installing a Sony CDX-565MXRF CD/MP3 changer in the trunk of my 01 TTR. It connects to the audio system through FM modulation (using, I believe, a direct connection to the antenna cable). I want to maount it in the cubby hole at the front of the trunk.
Have any of you done this? Any pointers and tips? Does FM modulation give poor sound qualtiy?
Some specific questions I know I have are:
- Is there an accessibile pass-through from the trunk to the passenger compartment for the control/display cable?
- Is the antenna cable relatively easy to get to from the trunk space?
- Is there a ready power lead in the trunk space to run the thing?
Thanks!
- Charlie<ul><li><a href="http://www.crutchfield.com/cgi-bin/S-chswOYfeSzZ/ProdView.asp?a=0&amp;s=0&amp;g=610&amp;id=essentia l_info&amp;i=158CDX565M">Sony CDX-565MXRF</a></li></ul>
Old Aug 23, 2002 | 08:57 AM
economisTTwo's Avatar
Member
Default i get a kick that "crutchfield" asks for car stereo advice! (i know you're not related.) anyway...
the fm modulated sound won't be able to sound any better than regular fm radio -- so you'll get less frequency response than you would with a cd. on the other hand, it shouldn't be worse sounding than fm, either.
Old Aug 23, 2002 | 11:57 AM
CharlieC's Avatar
New Member
Also, any pointers on how to remove the head unit?
papuc (MMI S4)
Apr 24, 2008 04:39 AM
Alpha6-27Tango(jeff)
Jul 12, 2005 09:18 PM
Kingttr
Apr 30, 2005 08:50 AM
mgonyea
Dec 8, 2004 01:31 PM
mikebmassey
Oct 22, 2004 08:20 AM
