Tire Warranty?
Old Aug 25, 2002 | 06:43 PM
CharlieC's Avatar
New Member
Default Tire Warranty?
Hey Folks,
Do the Bridgesotne Potenza RE040 tires that came on the 01 TTR 225 come with a mileage warranty?
My rear tires are completely shot, but the fronts still have a lot of tread (which seems odd, since the TT is supposed to be mostly front drive). One of the rears went flat today with the belts showing on the inner edge. The other is pretty bald as well.
I was thinking there must be an allignement issue (toe?) to produce such disparity of wear front-to-rear, but maybe I just got some bad tires...
I'm going in for service tomorrow (30K) and just wondered if I should try for any warranty relief.
Any thoughts?
Thanks!
- Charlie
Old Aug 25, 2002 | 06:46 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Your kidding, right?......
30K out of (so called) performance tires is more than anyone should expect. Sounds like you should have rotated them more frequently if you wanted more. Personally, I'd be happy with 20K out of a good tire. Remember, the harder they are the further they go. Do you value mileage or handling?
Old Aug 25, 2002 | 07:07 PM
CharlieC's Avatar
New Member
Default Re: Your kidding, right?......
I definitely value handling more than mileage... I just don't have much sense of how long these things should last.
So anything beyond 20K is good. Cool.
Thanks.
- Charlie
Old Aug 25, 2002 | 07:13 PM
axel's Avatar
Rotate every 5k miles, thats front to rear same side. Check TP at least every week.
TP's Avatar
TP
Junior Member
Many will tell you that anything over about 12K is gravy.
Old Aug 25, 2002 | 08:44 PM
BigTT's Avatar
Member
Default I only got 17K on the OEM 040's and 20K on S03's... the two tires are not in the same league....
S03's hands down winner on performance and oddly enough treadwear!!
Old Aug 25, 2002 | 09:34 PM
Lloyd of the Rings's Avatar
30K! 30K!! I got about 14,000 out of mine.
Old Aug 26, 2002 | 04:46 AM
CharlieC's Avatar
New Member
Default Wow, I'm luckier than I thought :-).
So why does a car that is "mostly front drive" wear out the rear tires so much more quickly than the fronts?
And I'm putting in my order for S03s today.
Thanks!
- Charlie
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 26, 2002 | 08:56 AM
Now that's wierd: it's my fronts that wear quickest.
Old Aug 26, 2002 | 04:40 PM
CharlieC's Avatar
New Member
Default Of course, now that I think about it...
I do use snow tires several months, so the mileage on the 040s is prob'ly more like 20k miles. Still not outrageous though.
On the fronts the tread depth is probably 150% of the wear bars.
The Audi guys are going to check it out tomorrow and see if they can find a reason for the disparity.
- Charlie
