How is the speedometer calibrated?? Mine seems to be strangely off...
Old May 4, 2003 | 12:39 PM
TTahoe's Avatar
Default How is the speedometer calibrated?? Mine seems to be strangely off...
<center><img src="http://pictureposter.audiworld.com/19014/calibrated.jpg"></center><p>Now I do have 18' rims w/ 235/40's and I'm not sure how far off that is from the stock 17' set-up but I'm assuming it threw off my speedo long ago. That is not my question....
My question IS...If I get on a very straight, flat piece of highway and I put the cruise control on 78MPH, then if I reset my avg MPH on the trip display it will read as a constant 76mph (as seen in the supplied pic)
So regardless of what size tires I have on...shouldn't the trip display be going of the speedo reading or is it just taking the speed off the wheels; and if that's the case, shouldn't it be reading a speed above what my speedometer is saying.
And don't tell me it's a bad cluster.
Old May 4, 2003 | 02:19 PM
msauve's Avatar
Default The speedo deliberately reads high, in compliance with German law...
the cluster is engineered to be closer to reality.
Old May 4, 2003 | 02:21 PM
TTeleven's Avatar
Default pointer may have been installed slightly off alignment
I don't know how they install the pointers during manufacture of the cluster but when I removed and replaced them for my white face gauges it would be very easy to install them in a position that doesn't agree with the digital display
relationship between tach and speedometer appears reasonable assuming in 5th gear
Old May 4, 2003 | 02:26 PM
Bob W.'s Avatar
25 Year Member
Default your speedo is 1.7% too slow...
when your speedo indicates 60mph, you're actually traveling 61.0mph.
calculator at the link below...<ul><li><a href="http://www.miata.net/garage/tirecalc.html">Tire size calculator</a></li></ul>
Old May 4, 2003 | 03:00 PM
TTahoe's Avatar
Thanks.
Old May 4, 2003 | 03:01 PM
TTahoe's Avatar
So I was traveling at 76mph, insted of the indicated 78?
Old May 4, 2003 | 03:02 PM
Bobby Ricigliano's Avatar
Junior Member
What kind of Law" would dictate that?
Old May 4, 2003 | 04:45 PM
SXSMITH's Avatar
Junior Member
Default GPS's are very accurate for speed. Speedo said 136 when I was going 135.
<center><img src="http://email.net/~scott/TT-Scott/TT120.jpg"></center><p>I had a similar experience (no photos) of speedo saying 143 and GPS said 141. So, less than 1% error but consistently high as other posts say here. 17" wheels.
 Pouria Savadkouei
 Michael S. Palmer
Old May 4, 2003 | 05:29 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Accurate enough for me...!!
Old May 4, 2003 | 05:56 PM
msauve's Avatar
Default German law requires speedos to NEVER read below actual,
therefore manufacturing tolerances require that manufacturers design in a "too high" reading.
