Lowering and Kmacs
Old Jan 30, 2004 | 05:02 AM
JPAmerica's Avatar
Junior Member
Default Lowering and Kmacs
How low can you lower (Front + Rear) before really needing Kmacs? Thanks
Old Jan 30, 2004 | 05:22 AM
02TTK04's Avatar
Member
Default 1.1 inches for the half kit. Pretty much just Eibachs. Anything more will need a full kit or camber
arms.
Old Jan 30, 2004 | 05:34 AM
audaciousTT's Avatar
Member
I went w/S-line..about 3/4...used adj arms..PERFECT!
Old Jan 30, 2004 | 07:43 AM
jam75944's Avatar
Junior Member
Default so with just eibachs you dont need to do anything else??
car will sit fine?,, no camber adjustment needed??
Old Jan 30, 2004 | 10:22 AM
Sheep's Avatar
Default Hey feller, do you have-->
a direct braodside jpeg of your car with the S-lines? Not an angled shot like I've seen you post, but direct side? Also, what diameter wheels would be in that shot if you can forward/post it? I've got 18's.
I have seriously been considering S-line instead of the Eibach/Bilsteins. I assume you didn't need K-macs or such....if necessary, I'm going with adjustable Forge arms.
Thanks, David (Sheep)
Emailing pic would be fine instead of posting: shihlha@earthlink.net
Old Jan 30, 2004 | 10:25 AM
Horch it's Avatar
Default how do you like your S-line and can you elaborate on ride quality
before and after? If I'm not mistaken, you got front shocks or Coilovers and 4 springs in kit, right? badges and door sills too. Thank you for any info you might provide.
Old Jan 30, 2004 | 01:57 PM
02TTK04's Avatar
Member
No, you need a 1/2 kit with Eibachs.
Old Jan 30, 2004 | 01:59 PM
Member
Default Love S-Line!>>>>
They 3/4 inch drop, but I swear it is more.
Yes it came with 4 springs and front shocks. I feel the ride quality is great...although I would prefer a little more rebound dampning in the rear...Dosent bother me though...I order just the badges not sills...for the price I think it is the best deal...also used forgr adj ties...tech said it was the easiest align he has done.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 30, 2004 | 02:01 PM
Member
Default This is the best I have...w/ 18's>>>
<center><img src="http://pictureposter.audiworld.com/62654/sabine.jpg"></center><p>I am now on the RS4 19' w/ P-zero Nero
Old Jan 30, 2004 | 02:19 PM
Horch it's Avatar
Default Great! thanks for info
so you did not need any spacers? and what is the tire gap to fender now? and last question: has your driving habits changed at all? I mean do you scrape the bottom of spoiler now because it is lower? TIA
