Next mod 180TTQ: lightweight pulleys + Inlet pipe or K04-001 ?
Old Jan 30, 2004 | 06:23 PM
GkRiKoRi's Avatar
Junior Member
Default Next mod 180TTQ: lightweight pulleys + Inlet pipe or K04-001 ?
I wonder if the K04 $795 comes with a new inlet pipe instead of reusing the original inlet pipe. Will it work fine with K03 GIAC programming and the ECS N75? or do I need to put back the stock N75 and reprogram the ECU?
Would the bolt-on K04-001 alone give the best performance for the money compared to the pulleys and the NEUSPEED inlet [~$220 each]?<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?html=info-Engine-Performance-Pulleys.html&amp;make=Audi&amp;model=TT&amp;submod el=Quattro&amp;engine=180HP">ECS Pulleys link</a></li></ul>
Old Jan 30, 2004 | 06:34 PM
mcgilla's Avatar
Default the issue will be around fueling....
...although you might get this to work without the 225 injectors...you'd best go with 225 injectors...you'll need a shhop that can do remapping via 4xdyno
ogre22
Aug 1, 2008 08:26 AM
DumpTTruck
Sep 5, 2007 08:38 PM
DynomiteTT
Oct 9, 2006 03:03 AM
SP (oenophile)
Jul 12, 2005 11:23 AM
cuatrokoop
Performance and Tuning
Apr 18, 2004 06:59 PM
