2 ?'s: Would 19 X 9 be a bad idea all the way around? If not ...
Old Jan 31, 2004 | 01:49 PM
Nogaro 2.7t's Avatar
Default 2 ?'s: Would 19 X 9 be a bad idea all the way around? If not ...
the wheels are: 19 x 9, et 30, what size spacers would I use to be flush, like the 15mm fronts and 25mm rears does to stock!!?? Wheels are the p2's by projeczwo
Old Jan 31, 2004 | 02:09 PM
TTear's Avatar
Default You may have a hard time fitting that rim in the front...
If you do, you should no way use any spacers for the front, unless you want to have rubbing issues. I'd say a 5mm spacer is the biggest you can add at the rear, and it will get you flush with the fender lip.
Old Jan 31, 2004 | 05:16 PM
Paul TTINGER's Avatar
how much you paying for the wheels ?
Old Jan 31, 2004 | 10:26 PM
They retail for $550 each
warz00
S4 (B9 Platform) Discussion
Sep 4, 2018 06:41 PM
downunder
10
Nov 8, 2007 12:17 PM
TwisTTer
18
Jun 30, 2005 07:51 PM
bostoned
Apr 18, 2005 10:35 AM
iborroel
16
May 3, 2004 03:33 PM
