How do I route wires under/within the area around the shift base?
If this makes any sense to anyone, how do I get into the housing area near the shift **** base and from there into the e-brake housing?
Ideas/pics?
TIA!
Lift up this edge, and this cover will come out.
it's captivated at the other end, so start at this end.
<img src="http://jbipes.home.comcast.net/jpgs/cover1.jpg">
You can get at the space under there, and run the wires out along the bottom of the plastic base on the tunnel where it meets the carpet.
You can then push the wires along this edge, and push them under the plastic. You can fish them out from the sides of the center console, under the radio/climate control.
<img src="http://jbipes.home.comcast.net/jpgs/cover2.jpg">
As for the routing, I'll o as you say and just tuck them up along the edge from the front of the car toward the area underneath the e-brake.
Cool - another fun project this weekend. :-)
Thanks Jeff.
<IMG SRC="http://woodyjdb.home.comcast.net/images/switch1.jpg">
<IMG SRC="http://woodyjdb.home.comcast.net/images/switch2.jpg">
<IMG SRC="http://woodyjdb.home.comcast.net/images/switch3.jpg">
<IMG SRC="http://woodyjdb.home.comcast.net/images/switch4.jpg">
<IMG SRC="http://woodyjdb.home.comcast.net/images/switch5.jpg">
<IMG SRC="http://jbipes.home.comcast.net/jpgs/swremove.jpg">
<IMG SRC="http://jbipes.home.comcast.net/jpgs/cntrconn.jpg">
<IMG SRC="http://jbipes.home.comcast.net/jpgs/centersw2.jpg">
<IMG SRC="http://jbipes.home.comcast.net/jpgs/swremove2.jpg">
