Turn signal problem, flashing is erratic and sometimes stops blinking
I don't have any bulbs out and it's both sides which are doing it. The emergency flashers don't seem to be acting erratically but I only tried them for 15-20 seconds last night.
From searching I see lots of mentions of the flasher relay. Is that it? And how much of the dash needs to be dissasembled to get to it? One person said the whole lower dash was removed, another said just the radio.
I have to go in for my 20k service soon anyway, but I'd like have a good idea exactly what's wrong.
tia
Rectified by warranty replacement of column switch.
There is no external "flasher".
Auid uses two relays in this button, and a bunch of electronics.
Each relay controls that particular side of the car.
Both relays are used when the flasher button is pressed.
Copper squares here.
<img src="http://mk1tt.montebellopark.com/images/emerswitch.jpg">
This switch may be bad.
Hope it's under warranty.
this has been reported to be a problem for a few people.
Yes, the switch needs to be replaced.
Yes, the dealer needs to do this.
Yes, the radio needs to be removed.
Yes, It will take a few hours to do this.
Since the flashers work, I'd bet it is probably the column switch. Thanks.
But, if both turns are erratic and the hazards work, I don't think it's the relays. Thoughts?
i have 2003TTC. for 2003 there is 2 relleys.
one is for emergency ony for the turn. changed both, after second was changed the problem went away.
as for serch there is nothing on TT side, i've sserched & posted it semes to be some new for TT,
if you serch all Audi it is comon in A4.
make your dealer change both relleys.
The emer. flasher circuit needs to flash 2X as many bulbs, so this circuit is isolated from the turn flasher part
The turns use a separte part of the circuit, and it may be that part that is not flashing properly.
