Question re "cool down" after hard (no pun intended) driving...
You can either let it idle for 2-3 minutes and draw the heat out of the turbo with the "cooler" oil.
You can install a turbo timer which will continue circulating the oil after you shut down. This will take the engine out of warranty.
You can use synthetic oil which will handle the high temperature much better than the "normal engine oil.
I seriously doubt that you could run hard enough just before parking at a convenience store to really have a concern. In my mind, you'd have to go from wide open to dead stop and really make an effort to *cause* a problem.
