Help!!!! is my Haldex shot?
Old Mar 24, 2004 | 10:57 AM
MoroBluMTM265's Avatar
New Member
Default Help!!!! is my Haldex shot?
First I was getting a resistance like brakes when backing up and turning at the same time. Now moving forward with the wheels turned all the way right or left I get a moaning sound from the rear and the inside rear wheel hops.
Is the haldex history or does it need a fluid change?
I have 18 k miles any feedback appreciated.
Old Mar 24, 2004 | 11:07 AM
BluHeaven's Avatar
sounds like a busted differential!!
Old Mar 24, 2004 | 11:09 AM
New Member
Great, any other opinions out there?
Old Mar 24, 2004 | 11:13 AM
BluHeaven's Avatar
Check your brakes as well, the rears could be stuck clamped to the rotor
Old Mar 24, 2004 | 11:44 AM
bone sTTock's Avatar
New Member
Default Doesn't sound like the haldex
From your discription I think you have a Differintial problem. The haldex really doesn't do anything until a front wheel slip is detected. Try and jack the rear of your car off the ground and spin one of the wheels...the other should spin in the reverse direction, if it doesn't it's probably your rear diff.
Old Mar 24, 2004 | 12:14 PM
New Member
thanks I will try that
Old Mar 24, 2004 | 12:56 PM
VA TT Coupe's Avatar
New Member
Yeah - I agree.....my truck did this a few times
Old Mar 24, 2004 | 04:35 PM
mcgilla's Avatar
Default the wheel hop may indicate a diff but some of these symtoms...
...are similar to low steering fliud...Add Pentosin 11S to your steering resevoir...if it's low.
 Pouria Savadkouei
 Michael S. Palmer
Reinman
Jul 7, 2010 09:08 PM
dee chaser
Dec 5, 2009 09:19 AM
20valvevermont
Apr 27, 2003 08:46 PM
CGTCOMM86
Mar 6, 2002 04:34 AM
