I want to remove aliens & disconect/remove motor. What size plug etc do I need?
I hear there are two washer motors... one runs the windshield washers and the other the aliens. Which one is which?? Can I completely remove the aliens motor?
If I do that, what will need to be done to plug the fluid lines off so I don't leak fluid? Where do I need to plug it off at and most importantly... what do I use to plug the line and in what size!!
Thanks!
Where the rubber line transitions to the alien disconnect. Just cut the rubber, slip in a 1/2 inch bolt 3/4 inch long and Put a hose clamp on it. Use a little silicone to seal it good, or just find a smooth unthreaded plug. You'll be good to go and all set to hook up mister lines in the future if you decide!
that and I want to install the FMIC one day so might as well get that part over with now lol
...... when I wax my car I sure will follow Schwig's instructions.
