DAMMIT!!! Got the wrong bloody connector AGAIN! :-(
Old Mar 24, 2004 | 02:46 PM
Marc3.2TT's Avatar
Default DAMMIT!!! Got the wrong bloody connector AGAIN! :-(
In an effort to integrate the Clarion VRX935VD head unit I've pulled from my "old" GTI into the TT, I ordered the Scosche VW01B wiring harness last week and managed to connect most of the head unit's wires through the harness.
Unfortunately, the VW01B only includes the top two connectors of the stock head unit:
<img src="http://ttbipes.home.comcast.net/jpgs/headunitwiring.jpg">
and as it appears, the rear speakers, that are powered by an internal Audi "Power Amp", must be connected through the bottom connector with "RR LR COM" pins above.
So, I found this VWK1 harness on the same website as the one I had ordered the VW01B through:
<img src="http://images.cardomain.com/products/sco/SCOVWK1B.jpg">
which is apparently for VAG products with "Aktiv Amplified Option". It looked like that third connector from the wiring diagram above was included in the kit, so I went ahead and ordered it.
Well guess what, it's not even close to the right connector!!
This is the package I received:
<img src="http://hitechgti.50megs.com/audi/carkit/DSC00060.jpg">
and this is what the connectors look like:
<img src="http://hitechgti.50megs.com/audi/carkit/DSC00061.jpg">
You'll notice the top two are correct (just like in the VW01B adapter), however the bottom one is completely wrong:
<img src="http://hitechgti.50megs.com/audi/carkit/DSC00062.jpg">
As you can see, the pins are completely the wrong size &amp; layout:
<img src="http://hitechgti.50megs.com/audi/carkit/Dsc00063.jpg">
Where in the world can I possibly find the right connector??
Help greatly appreciated..
-Marc
Old Mar 24, 2004 | 02:51 PM
BluHeaven's Avatar
Default just make your own :)
pull the pins and splice the wires together
=D
ok no not really... sorry I have no clue. Maybe try a stereo shop and see what they come up with?
Old Mar 24, 2004 | 03:02 PM
John P. (TT 225)'s Avatar
Do you have the Bose system?
Old Mar 24, 2004 | 03:05 PM
Marc3.2TT's Avatar
Nope, stock Concert crappola system
Old Mar 24, 2004 | 03:11 PM
Marc3.2TT's Avatar
Default BTW do you know what this "Maystar" adapter is?
Got this from Andy (aka MacSub) from the Audio/electronics forum:
<img src="http://pictureposter.audiworld.com/66252/rca_adapter_female.jpg">
Looks like the red connector in this pic is what I need, with the RCA line inputs..
Default Okay good. So you're essentially just sending signal, ground, & remote signal
to the rear self-amplified speakers then.
There is no connector for this piece that I'm aware of. When you use the Concert to power aftermarket amps, then you can use an adapter by Blaupunkt but that's of no use here.
If your Clarion has low-level (speaker) outs for front &amp; rear, you could always run wire to the rear speakers (as I've done) to power them with the aftermarket receiver. They're 4-Ohms, so an aftermarket receiver works fine. You just wire directly to the + &amp; - leads on the speakers.
Of course, you probably don't want to pull all those panels. Your option is to then the get some RCA cables, cut the ends off, and itegrate into the stock plug.
Old Mar 24, 2004 | 03:17 PM
Marc3.2TT's Avatar
Default Gotcha, thanks for the response.. now a couple more questions:
Are you saying that the Concert does NOT have a power amp for the rear speakers, or that it DOES?
If it does, then how would line outputs from the Clarion (which does have them BTW) be able to feed the +/- directly on the speakers??
Really confused here..
Old Mar 24, 2004 | 03:30 PM
Marc3.2TT's Avatar
Default Bingo!!! Look what I found:
<img src="http://www.stceurope.com/images/autoleads/pc9-404.jpg">
Could that possibly be it???
Only problem is that they're in.. Belgium!!
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 24, 2004 | 04:00 PM
SGK's Avatar
SGK
New Member
Default Try Crutchfield- got a look alike part there
That sure looks a lot like the two part Blaupunkt adapter that Crutchfield sold me to put a Hamburg in my New Beetle Monsoon system. They will help find the right parts even if you only want the adapter and not a new head unit.
Old Mar 24, 2004 | 04:25 PM
It does not. It only has amplied fronts. It sends signal to the rears only.
