Question for those who have a gauge in their vent...
Old Mar 24, 2004 | 08:11 PM
CDN RDSTTER's Avatar
New Member
Default Question for those who have a gauge in their vent...
How did you remove the fins from inside the vent?
I've taken the vent from the car, however I don't want to break any of the fins if I don't have to.
Thanks for the input!!!
Old Mar 24, 2004 | 08:20 PM
riso's Avatar
Junior Member
Default Get the APR pod!
<center><img src="http://pictureposter.audiworld.com/62703/dsc00007.jpg"></center><p>
Old Mar 24, 2004 | 08:26 PM
sofTTware's Avatar
Junior Member
Why would this be prefered over the AWE one that allows air-flow around the outsides of the gage?
Old Mar 24, 2004 | 08:28 PM
JerseyTT2's Avatar
Default Re: What size gauge are you using? >>
i believe all your looking to do is remover the ring, correct?
Old Mar 24, 2004 | 08:30 PM
riso's Avatar
Junior Member
Default The center vents share the same air pipe behine!!
Once you put the gauge on, whatever Defi or AWE, you are going to loose control on the air direction.
Even you block one vent, the other will give you the same total amount of air.
Old Mar 24, 2004 | 08:31 PM
riso's Avatar
Junior Member
Bigger is better 60mm.
Old Mar 24, 2004 | 08:34 PM
New Member
Default yes I'm using a 60mm... more...
however there's a rear fin that is controlled by the outside ring, I can't seem to remove that one, however if I don't, it seems as though the gauge actually hits the fin...
Old Mar 24, 2004 | 08:39 PM
resurrecttion's Avatar
Junior Member
Default doable.
<center><img src="http://images5.fotki.com/v64/photos/1/19262/803220/IMG_1304-vi.jpg"></center><p>
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 24, 2004 | 08:45 PM
riso's Avatar
Junior Member
I don't think 60mm will fit without shaving the plastic inside.
Old Mar 24, 2004 | 08:52 PM
Junior Member
Default shaveless.
<img src="http://images5.fotki.com/v63/photos/1/19262/803220/IMG_1310-vi.jpg">
<img src="http://images5.fotki.com/v64/photos/1/19262/803220/IMG_1317-vi.jpg">
