Ok... I can't seem to find a conversion chart for bar and psi (boost pressure) (more)
Old Mar 24, 2004 | 10:59 PM
Greyhaven7's Avatar
Default Ok... I can't seem to find a conversion chart for bar and psi (boost pressure) (more)
anyone know where I can find one? I don't know what "bar" is related to pounds of boost so I'd like to figure this out.
Old Mar 24, 2004 | 11:01 PM
EasTTcoasTT's Avatar
Senior Member
1 bar = 14.7psi
Old Mar 25, 2004 | 12:08 AM
Greyhaven7's Avatar
THANK YOU! ...... that's a lot a' psi. we run what... 8 stock 21 max (somehting like that right?)
Old Mar 25, 2004 | 06:16 AM
ModifiedA4's Avatar
Banned
Default actually its 14.5 PSI....
the problem comes when people make the assumption that 1bar = 1 atmosphere (which for 99% of the calculations out there, its close enough).
1 atmosphere = 14.7psi.
1 bar = .987 atmosphere.
Old Mar 25, 2004 | 06:27 AM
TTown's Avatar
New Member
I thought it was 14.7 also.... can someone set the record straight?
Old Mar 25, 2004 | 06:28 AM
ModifiedA4's Avatar
Banned
i thought i did.
Old Mar 25, 2004 | 06:55 AM
Senior Member
Default You did... I defer... You're right....
G-ddamn meteorology class.. I should've remember that.
Old Mar 25, 2004 | 07:04 AM
TTown's Avatar
New Member
Default why the difference for automotive use?
Atmospheric pressure ( 1 bar) = 14.7 psi as far as it is taught in a classroom - why the difference for our application? Not trying to be smart - but I would like to know.<ul><li><a href="http://www.mech.utah.edu/~isaacson/tutorial/pressure.html">http://www.mech.utah.edu/~isaacson/tutorial/pressure.html</a</li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 25, 2004 | 07:10 AM
Senior Member
Default They take out the .987 conversion between bar and atmosphere...
Which for all intents and purposes is usually negligeable.
For automotive use.. use 14.5, 15, whatever is easier to multiply in your head. :-)
Old Mar 25, 2004 | 07:11 AM
ModifiedA4's Avatar
Banned
its a simplification assuming 1bar = 1 atm.
