The electric windows used to go down half an inch when the door is open, but it didnt work today, y?
Old Mar 25, 2004 | 04:12 AM
watsonswater's Avatar
New Member
Default The electric windows used to go down half an inch when the door is open, but it didnt work today, y?
It used to go down a bit when the door is opened, but today seems no working this way, anyone has any idea?
Old Mar 25, 2004 | 04:17 AM
andrew.tt's Avatar
do a search for "resetting windows" or the like.
Old Mar 25, 2004 | 04:36 AM
Tongpo~Dr. Evil's Avatar
Member
Default mine messed up cause the door sensor didn't realize the door was open
does the door open signal show up on the center of ur dash?
Old Mar 25, 2004 | 05:20 AM
New Member
It does show my door(s) and the boot open, but the windows wont put down when opened
Old Mar 25, 2004 | 05:43 AM
TTear's Avatar
Where are you located? It happens sometimes when it's frickin' freezing
Old Mar 25, 2004 | 06:06 AM
VenTTed's Avatar
do the reset search and your issue will be fixed.
Old Mar 25, 2004 | 06:10 AM
New Member
Default reseted many time by the procedure from the manual... It wont work!!
The one touch function has work after I reset at the first place, just the drop off feature not work!!
Old Mar 25, 2004 | 08:02 AM
CWK_Marin's Avatar
Junior Member
Default Window problems are a known problem for TT.
If you are on warranty take the car to your dealer. Window problems are fixed under warranty. The dealer will probably replace the window motor(s) at no cost under warranty.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 25, 2004 | 08:52 AM
TTurbo's Avatar
Default Don't get me started on window motor issues....
After at least 6 trips to the dealer in about 7 months time, and 7 or so window motors and switches later....mine seems to be back to normal. Knock on wood. It wouldn't surprise me to see this thing creep up in an '00 or'01 TT out of nowhere. All I can say is, I hope you are still under warranty. Good luck!!
Old Mar 25, 2004 | 09:10 AM
Audi Frank's Avatar
New Member
try opening and closing the roof... worked for me
Plutolawyer
A7
Oct 7, 2013 03:39 AM
dany0212
Sep 5, 2008 12:14 PM
NJAllroad
Audi allroad
May 23, 2008 08:24 AM
A6Fanboi
11
Nov 8, 2005 05:41 PM
