Mr. Bipes - I looked in your "How To" section but...
is there a way to get only the front parking lights to come on when car is turned on, like on the Corvette (ie. Daytime running lamps)
TIA
You can get at these from the headlight switch.
The problem is, that if you power these from an ignition turn-on source, you will get the rear tail-lights on also.
You will need to go right to the actual wires going to the parking lights, and wire in a separate wire to the points. You will need to use a diode on the main parking light signal from the headlight, to isolate this signal, so it does not feed-back into the rest of the wiring harness.
