One thing leads to another... the consensus is now it needs to be lower>>>
AS for difficulty, I'd say the rear swap is moderately difficult, but the fronts are very difficult and need expertice. And you will need an alignment once everything is done.
Lastly, from a cost perspective, the install of struts and springs should be done at the same time. Since the work is basically the same to do 1 or both.
As far as cost, estimate $250 for the springs, $500 for the shocks and another $250-400 for the install (depends on your area and who you go to). Get an alignment done after things settle down with the car (2-3 weeks should be enough if you drive a lot). Don't forget you'll need some sort of camber correction when you lower. I used half of a KMAC kit and my camber is in spec. Make sure they look at rear toe very closely or you'll end up burning your tires very fast.
I am giving it a try, but am ready to get shocks if needs be.
The idea is the shocks have not had a chance to establish a wear point in the travel. Once they do they will wear out quicker. That point is loosely given as 1000 miles.
Therefore, if you are quick about switching them out you will likely get by with just springs. This of course is assuming a decent brand shock to begin with, which we do have.
However, if it were me, I would buy some coilovers and not risk it. The coilovers will give you just about any ride height you want and a great ride to boot. I am considering the KW coilovers.
Installation wasn't bad and the garage is fine as long as you have jack stands.
Ride as 'slightly' stiffer than stock. Not harsh though.
Alignment is required after as the camber will change.
I would advise to change the shocks as you don't want to repeat this twice. (The stock shocks don't last long).
One other thing, a 1/2 k-mac in the lower control arm of the rear allows for camber adjustment.
Pics on my fotki site.
Hope this helps.
-Robert
