Need advice. Having a tranny removed next week. Should I swap the clutch while I'm at it?
Old Mar 26, 2004 | 09:02 AM
maaliish's Avatar
Default Need advice. Having a tranny removed next week. Should I swap the clutch while I'm at it?
The car is 225hp 2001 with about 50K on odometer.
Dealer is replacing second gear, so I might be able to use the oportunity to swap the clutch. The clutch seems to hold strong so not that there's anything wrong with it, but should I swap it anyway? Whats a good clutch for 225TT?
Thanks.
Old Mar 26, 2004 | 09:04 AM
coasTTal's Avatar
I would do heavy duty clutch and lightweight flywheel at the same time.
Old Mar 26, 2004 | 09:11 AM
maaliish's Avatar
Default Even if the stock one is still holding pretty good? I don't plan
on racing the car, but I will most likely do a chip upgrade.
Old Mar 26, 2004 | 09:34 AM
HACK THS's Avatar
lets just say the only harm of this upgrade is to the pocket book ;-)
Old Mar 26, 2004 | 09:43 AM
ElemTTRo's Avatar
clutch only if you're not doing more mods...
Old Mar 26, 2004 | 09:53 AM
RedRoadster's Avatar
Member
No need for mroe than stock if you are not tracking car, and not going beyond chip.
Old Mar 26, 2004 | 10:00 AM
TTGram's Avatar
Member
Default I have over 50000 and am noticing some slippage under hard ecceleration >>.
Perfect chance to swap clutch.
Old Mar 26, 2004 | 10:43 AM
EasTTcoasTT's Avatar
Senior Member
Default With a chip though, you could get a stage 2 spec (street clutch, not track)
It couldn't hurt.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 26, 2004 | 11:19 AM
maaliish's Avatar
Thanks for tips.
Old Mar 26, 2004 | 01:15 PM
SparTTan's Avatar
Default I had my tranny rebuilt around 42K and asked dealer to replace the clutch also.
They did it under warranty. You are allowed one clutch replacement while under warranty, but they will only replace it if it is worn out. So smoke the hell out of it until next week!
Of course, YMMV depending on the particular dealer.
philo.beddoe
Apr 25, 2008 07:54 AM
El Desamparado
Audi Original "S" Cars
May 2, 2007 06:26 AM
Nogaro-2-Sprint
Feb 5, 2007 06:05 AM
HKsupastar
23
Dec 4, 2004 04:55 PM
ukDIESELdriver
Nov 11, 2003 06:12 AM
