No intake, but 75 degrees and had to do something ! can you see the difference ??
Old Mar 27, 2004 | 12:39 PM
MOBlueTT's Avatar
Member
Default No intake, but 75 degrees and had to do something ! can you see the difference ??
Before - look at right side *seam*
<img src="http://pictureposter.audiworld.com/30405/spring_04_tt_mods_016.jpg">
After - (sorry for the depth of field problem)
<img src="http://pictureposter.audiworld.com/30405/dscn1390.jpg">
a little 220 grit, a little time... a little metal polish... MUCH smoother for an hour of work and Ready for EH Project to Arrive
Old Mar 27, 2004 | 01:08 PM
BluHeaven's Avatar
so... how are you going to get the grit out??
Old Mar 27, 2004 | 01:16 PM
MOBlueTT's Avatar
Member
Default Actuallly that was easy... plug the intake when polishing / Shop Vac >>>
What you see is build-up on the valves before any work... 26 K miles... I haven't tried to see how stubborn those are yet.
Old Mar 27, 2004 | 01:18 PM
BluHeaven's Avatar
Default ahh good... I didnt think you would sand on it un protected but
you never know!!!
Old Mar 27, 2004 | 01:23 PM
MOBlueTT's Avatar
Member
Default We have all had those Oh S*** Moments... but not this time... Now >>>
<center><img src="http://pictureposter.audiworld.com/30405/dscn1395.jpg"></center><p>I wasn't ready to go the WHOLE route like the Wilson TB porting, but I DID something they Didn't... can you tell ??
Old Mar 27, 2004 | 01:26 PM
BluHeaven's Avatar
Default nope cant :(
whilw I've seen the insides of alot of TBs and even gasket matched my own.. I've never looked at a stock TT TB before to compare to your pic
Old Mar 27, 2004 | 01:29 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
I can!
Old Mar 27, 2004 | 01:33 PM
BluHeaven's Avatar
Default do tell :)
cuase I'm not gonna to pull my IC hose off just to look at my TB and compare =P
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 27, 2004 | 01:37 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Gil is screwin around again.....>
With his screws...:-) He's ground/flushed the TB plate attaching screws... That always surprised me about the Wilson job...Intricate Port work on the TB, then those gnarly bolts sticking into the airstream..
Old Mar 27, 2004 | 01:41 PM
BluHeaven's Avatar
Default ahhhh!!! I see now ! It didnt jump out at me because
the TBs I've worked over the screws were already flush like that (mustang stuff) Although some of them had problems with the screws comming out and being sucked down the intake =O
thank god I never had THAT problem hehe!
