2001 vs. 2002
Thanks
50k miles. Instrument cluster was replaced under warranty. Privacy shelf was replaced a couple of times for rattles. New Haldex controller to reduce interference with AM reception.
I made them replace the rear glass because of some distortion.
There's probably more variation between cars than between years.
My car doesn't have the affected coil packs.
1) cluster
2) fuel sender
3) coil packs
4) front sway bar creaks
and some few other minor issues. other than that, you figure, after 4 years, you should be in the clear. I would probably get a 2002 if I had a choice, even if it was a few dollars more.
This forum is a great source of knowledge of the TT so most people come here to find answers to their service questions and share tech tips.
If there is a problem with somones TT, you will hear it here first. Dont let that give you the impression that all or even most TT's are problem cars.
2001 or 2002? The 2001 is the first year for the 225hp motor so there may be a few "First year issues". Not enough to not buy a pre-owned 2001.
If you find a nice clean 2001, go for it.
central locking unit replaced
privacy shelf replaced
privacy shelf replaced again
clutch cylinder replaced
clutch cylinder replaced again
hazard light switch replaced
hazard light switch replaced again
ESP sensor (longitudinal 1) replaced
ESP sensor (longitudinal 2) replaced
All of these occured in a period of less than 2 years (total of 45 days in the shop). So I would stronly recommend not buying a 2001 model year.
