If my DV wasnt holding boost under high loads what would it feel/sound like?
Old Apr 9, 2004 | 02:23 PM
BluHeaven's Avatar
Default If my DV wasnt holding boost under high loads what would it feel/sound like?
I don't mean like a bad DV. But perhaps boost pressure just high enough to open the DV and let it vent boost when it should be holding shut
I'm wondering if this hiccup I get during the screech (which occurs at the peak of the problem and results in a short burst of consecutive hiccups that you can feel) is the DV not holding to the boost levels and if so would a stiffer spring or a conversion to an adjustable HB help?
I still don't know enough about turbo cars and DVs and such to diagnose all thats going on.
gesTTalt, maybe if you make it down here on your trip back you can take a listen?
Old Apr 9, 2004 | 02:26 PM
DirtyVegasTT's Avatar
Default The way I spotted that problem with my car was when the pull wasn't consistent between drives.
It would pull great from one stop light. Then, half an hour later it seemed as if something was missing. My problem was fixed by a HyperBoost adjustable DV.
Old Apr 9, 2004 | 02:28 PM
02TTK04's Avatar
Member
Default Try the washer mod or a stiffer spring. If you feel that you aren't holding boost then that is all
you need, not a whole new DV.
Old Apr 9, 2004 | 02:45 PM
I got the upgrade kit, not a brand new DV.
Old Apr 9, 2004 | 05:21 PM
juliem's Avatar
Default well that sounds familiar
pre washer-mod ...
Old Apr 9, 2004 | 05:31 PM
kodeTT's Avatar
Elder Member
Default How long has your Hyperboost been in? leaks? Dirty? needs grease?
Maybe that's where your weak link is. Take it out and check it again...and while you're at it, lube it up with Mobil 1 syn grease. You need to cut down your variables...narrow it down to the location. maybe switch the Hyperboost to stock or something other than what you have....see if you have same issues/problems.
Old Apr 9, 2004 | 06:08 PM
BluHeaven's Avatar
Do you think the washer mod, a heavier spring, or moving to an adjustable would help?
Old Apr 9, 2004 | 06:09 PM
BluHeaven's Avatar
Its only 4 months old
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 9, 2004 | 06:22 PM
juliem's Avatar
Default i'm guessing the washers == heavier spring
but I didn't try that in specific so I can't say beyond a guess. I used 2 washers.
Old Apr 9, 2004 | 06:47 PM
BluHeaven's Avatar
Default I emailed strat, maybe they can send me the heavier spring out of the HX valve
or perhaps one of the forge springs would work?
we'll see.
