Front camber kit and sway bar?
Old Apr 9, 2004 | 02:45 PM
ILLZ's Avatar
Default Front camber kit and sway bar?
Or just the rear of each?
Old Apr 9, 2004 | 02:47 PM
02TTK04's Avatar
Member
Default No need for a front camber kit, plenty of room for adjustment built in already, if you have a
quattro and plan on lowering it more then an inch then you will need a camber kit for the rear.
Old Apr 9, 2004 | 03:13 PM
mcgilla's Avatar
Default no need for front camber...I have both the 25mm front bar and the 19mm rear bar...
...front bar tightens up the nose on long sweepers and improves high speed stability. The front bar is a 2 1/2 hour install with alignment vs. the rear bar's 1 hour install.
stormy down
Sep 28, 2007 01:37 PM
Silver
Feb 16, 2006 11:44 AM
hearTT
Jun 25, 2004 07:18 AM
jaxjax
14
Mar 9, 2004 06:36 AM
AlanBDahl
11
Jan 26, 2004 07:59 PM
