MAF Screens: which ones to take out? Did a search, read the article; 2001 180, w/BMC CDA.
Old Apr 9, 2004 | 05:42 PM
GorTT's Avatar
Default MAF Screens: which ones to take out? Did a search, read the article; 2001 180, w/BMC CDA.
Can the metal screen stay in place if the plastic in front (airbox side) is removed? Could both plastic screens (only) be pulled?
Old Apr 9, 2004 | 05:45 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You can...>>
Remove them all or just run with the screen if you choose. Best performance/flow will be running bare, but you must exercise some caution...Nothing between the air filter and the Turbo...
Take you BMC apart also and cut out the swirl tabs in the support structure. Leave enough tab to keep the filter centered. The swirl effect is disruptive and not necessary.
Old Apr 9, 2004 | 05:53 PM
GorTT's Avatar
Default Thanks, Schwing; I see the BMC comes w/a 2.5" hose,
but a sleeve pulls out and it looks like I can fit a 3 or 3.25" to it w/out too much trouble...
Old Apr 9, 2004 | 06:01 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup, but hard to route...>
A big hose...That's why my TTDA has dual 2.5's for a little more flexibility.....
Old Apr 9, 2004 | 06:09 PM
GorTT's Avatar
Default Yeah, this place is littered with folks that have seen the light!
I don't doubt I'll be one someday...Just fwiw, there's a couple of real quality issues with the BMC - like the foam 'sealing ring', that should be a real o-ring so it doesn't spew foam parts from the first fit, back into the maf...
Old Apr 9, 2004 | 08:44 PM
artinmoTTion's Avatar
OK, I'm "bare" now...what caution must I exercise? (Seriously!!)
Old Apr 10, 2004 | 03:22 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Never, ever run without..>>
A filter on.....Keep Cats and small children out of your engine compartment too lest they be sucked to their doom!
Old Apr 10, 2004 | 05:26 AM
Default : ) Some people run the car without an air filter? >>
Wow, even I knew that one! : )
I was going to buy one or two of those VW MAF's that were on special in the vortex thread the other day after I figured out if they would work. Did you see that thread? Not sure if it was a compatible one or not? I'll do some searching, but always reassuring to have your input on this stuff! : )
Thanks,
Rich<ul><li><a href="http://www.performance-cafe.com/catalog/product_info.php?products_id=787">MAF "special"</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 10, 2004 | 05:29 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default That's the one, but...>>
Might try pricing one out at your local VW dealer (it's for a 2.0 golf/jetta) as some have reported picking them up for a little over $50!
Old Apr 10, 2004 | 05:49 AM
thanks once again.
JPRobertsons
Apr 28, 2008 12:37 PM
Kingttr
Oct 21, 2007 10:14 PM
thewatcher101
May 21, 2007 04:46 AM
rs4s4
14
Jan 29, 2004 04:18 PM
eug (MK V)
11
Nov 27, 2001 05:50 PM
