More MAF questions...
Old Apr 10, 2004 | 07:51 AM
GorTT's Avatar
Default More MAF questions...
Does the VW Golf unit just have screens, or does it also have plastic flow straighteners (or, with some other combination than we have)? What (other) advantages does it have?
Old Apr 10, 2004 | 08:20 AM
artinmoTTion's Avatar
Default as far as I understand it, it's just cheaper, and works (just have to put it in our housing.)
Not sure what screens, etc. it has. Aren't those part of the housing that's in the TT MAF?
Rich
Old Apr 10, 2004 | 08:49 AM
jtntsfr's Avatar
Junior Member
You Just Use The Sensor Part!
Old Apr 10, 2004 | 10:40 AM
GorTT's Avatar
Default Ok; I thought maybe it was a different design, (no flow straighteners, just screens) and I could
swap it out for the stock w/my CDA or (or a TTDA) - that way I'd keep the stock unit intact if for any reason i wanted to go back to the factory airbox...
Old Apr 10, 2004 | 11:21 AM
TTapsale's Avatar
I have a 180 & used the housing & sensor.No issues.Don't know if this applies to 225's.
Old Apr 10, 2004 | 12:40 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Remove the element from the VW piece...>>
<center><img src="http://images1.fotki.com/v7/photos/7/7305/132592/DSCF0107-vi.jpg"></center><p>And put in your existing MAF housing. They are a different diameter. The only important part is the element seen on the right.. (This for 225's, 180's can swap the whole thing.) All have the screens in them.
Old Apr 10, 2004 | 02:54 PM
GorTT's Avatar
Default Steve, I've been giving it some thought, and
it seems that only taking one of the flow straighteners (f/s) out doesn't really get you there (which I'd hoped it would) - any testing or comments - it seems each f/s limits the airflow area by about 50%, and if I still have one, will it make a difference?
Old Apr 10, 2004 | 02:59 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default If you've read...>
The Autospeed article (and I think you said you did) then you know that the biggest intake restriction is in the MAF. I've run with them in, with just the screen, and with them out. Out is definitely better...<ul><li><a href="http://www.autospeed.com/cms/article.html?&amp;A=0629">Eliminating Negative Boost</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 10, 2004 | 03:04 PM
GorTT's Avatar
Default I did - but I was confusing the MAF with the entire unit (housing and all..) is the
sensing unit (the maf) actually smaller also?
Old Apr 10, 2004 | 03:12 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You really can't change the element size....>>
<center><img src="http://images5.fotki.com/v62/photos/7/7305/750827/IMG_6829-vi.jpg"></center><p>
It's a restriction you just can't get around. Cleaning up the screens/Vanes is all you can do easily to improve flow. "MAF" generally refers to the whole assembly. I'm working on a slightly bigger tube that will bolt in and should flow 11% more air. Untested though at this time...
