OK SAMCO intake hose and REVO now need some help
so i heard that some of you are having some 'noise' problem and i wanna know if what i am hearing is the same thing (even AFTER the SAMCO intake hose)
and this is after the REVO install
a 'wind' noise coming from the turbo it is not a loud creeching sound but it sounds like 'wind' noise from the turbo....
this ALSO ONLY happen at 3k-4k rpm (when you have a WOT) once it passes 4k the sound is GONE (even at near redline speed)i just installed the SAMCO so it should be pretty tight on the clamps (the only one that i might have some doubt is the connection btw the turbo and the SAMCO since it was a HARD one to get to)
power is GREAT i can feel a HUGE diff after REVO
so now my question is....is this the 'noise' that you folks are refering to after the REVO upgrade?? (or do i have something else??)
if it is.....anything else i can do?? (i have also tightened up the intercooler hoses)
thanks for the help
the noise is not sounds anything like metal grinding or anything like that....is a light wind noise (kindda like the DV letting off but lighter)
and if i switch back to stock mode its gone
i am thinking could this just be because the turbo is running at a high boost range that's why its louder
