Hood release problem
Old Apr 11, 2004 | 09:23 PM
TTuned's Avatar
Default Hood release problem
Pulling the hood release lever in the car does not release the hood..I have already tried the screwdriver and coat hanger method without much success. Anything else I can try?
Old Apr 11, 2004 | 09:26 PM
TTGram's Avatar
Member
Have you tried pushing down on your hood? Some times they stick.
Old Apr 11, 2004 | 09:29 PM
TTuned's Avatar
Yea, I tried that several times thinking that would release it
Old Apr 11, 2004 | 11:23 PM
TTapsale's Avatar
Default Try going over a slight bump while holding the hood lever in the open ...
position.It might jar it loose.
Old Apr 12, 2004 | 06:55 AM
TTuned's Avatar
Can I go thru the grill to pry it open with a screwdriver??
Old Apr 12, 2004 | 09:17 AM
TTapsale's Avatar
Default I'm not really sure but I would try to finesse it if you do. You can probably make things worse ...
w/ the screwdriver.
Old Apr 12, 2004 | 09:58 AM
TTuned's Avatar
Default What about....
I remove the belly pan from under the car and approach it from underneath??
4Jerry5
Feb 23, 2009 12:30 PM
S4armer
11
Jan 31, 2007 09:58 AM
Corey
Nov 29, 2005 08:15 AM
mgonyea
Jan 10, 2005 11:51 AM
pzero man
9
Jun 4, 2002 06:55 AM
