In terms of performance, is there an optimum size of wheel?...
I was just reading a review on the R32, and the author was wishing for a wheel 1" *less* in diameter.
So that begs the question, is there an optimum wheel size for our purposes, viewing the question solely from a performance standpoint?
Just increasing the rim, keeping the outer wheel diameter the same (plus one sizing) probably doesn't impact performance -- unless you're adding more unsprung weight (which of course, you are, by adding heavier rims).
Their analysis was (and I believe the physics holds) is that adding weight in the rims has twice the impact to acceleration, and moreso to braking than just adding sprung weight.
With that said, they though plus one sizing was the _most_ they'd recommend, it wouldn't hit performance too badly.
I suspect that the difference between 18" and 17" is minimal, in both weight and in sidewall stiffness. You're going from a 45 profile to a 40 profile (e.g. 225/45-17 vs 225/40-18) with a Y or W rating. I recall the days when VR50 was considered extreme.
And keeping the same rolling diameter effectively means the tires will have a shorter sidewall, thus less tire flex and better handling.
The biggest thing I learned is that the car will handle _much_ better with tires overinflated by 5 psi, than underinflated by 5 psi...
later
