has ANY one done the poly bushings for the front control arms?
Old Apr 12, 2004 | 03:42 PM
M power this!'s Avatar
Default has ANY one done the poly bushings for the front control arms?
i have both the front bushings (to copy mkI arms) and the swaybar bushings. swaybar didn't fit, but i'll get that handled. for the control arms, you need to remove the stock bushings and i'm curious how hard it is to do. they say to cut one end off and shove it through, but i somehow doubt it'll be that easy. i don't want to be out there with a torch and molten rubber is all.
Old Apr 12, 2004 | 04:11 PM
JustJeff's Avatar
next week, late
Old Apr 12, 2004 | 05:07 PM
kodeTT's Avatar
Elder Member
Default you brave soul....
you may be the only one so far!
Old Apr 12, 2004 | 05:56 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I believe Someone's done a set already....
YOu can bet there are some done in the UK..
Old Apr 12, 2004 | 06:31 PM
Default yeah, we shall see how hard it is real soon.
i just pray i don't end up with a squeeky car in the end.
Old Apr 12, 2004 | 07:58 PM
slater's Avatar
Default haven't done the control arm bushings yet... soon though. i just did the pendulum mount bushings on
saturday... WONDERFUL difference, and only $25! took me 15 minutes. high-rpm downshifting is much smoother, and engine movement/rocking in general has been reduced.
also, i think you'll need to press the bushings out.
peter
Old Apr 12, 2004 | 08:35 PM
That damn Dan's Avatar
Default Use an 1/8th in. drill bit to dig out some of the rubber first.
I used this technique on my KMACs and it turned a bitch into a breeze. Aint no goin back once you start though.
Dan
Old Apr 13, 2004 | 08:11 AM
CarlM's Avatar
Default Had mine done last week.
Still evaluating. It is not a night and day difference. I also had new tires put on (Goodyear F1s) so it is hard to tell exactly what the contribution of the bushings are. Steering seems a bit "lighter".
My mechanic thought the install was a bit of a pain in that there were no instructions. Other than figuring out orientations and whatnot, he did not report any problems.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 13, 2004 | 08:25 AM
slater's Avatar
do you have the MK1 arms or the MK2 arms? just curious where your reference point is...
Old Apr 13, 2004 | 10:33 AM
CarlM's Avatar
MK2s. Have never tried MK1s.
big_anthoiny
Nov 4, 2008 03:13 AM
Supercoupe
Feb 6, 2007 05:33 PM
M power this!
May 11, 2004 10:00 AM
Don@STaSIS
11
Aug 11, 2003 09:54 AM
silverbullet
Sep 9, 2000 06:55 PM
