Radio and Warranty
Old Apr 12, 2004 | 06:46 PM
boxx's Avatar
New Member
Default Radio and Warranty
Will adding and Aux input to the radio void my warranty? (Some wire cutting might be needed)
Old Apr 13, 2004 | 07:01 AM
JustJeff's Avatar
Not if you only work on the wiring harness, and not the H/U itself. what are you doing?
Old Apr 13, 2004 | 02:28 PM
boxx's Avatar
New Member
Default Re: Not if you only work on the wiring harness, and not the H/U itself. what are you doing?
Jeff,
thanks for replying. Actually, i'm putting in a bypass with a switch for the CD changer based on your design. It is for play tunes from the ipod or GPS for my pocketpc. Bypass so that there is no cutting.
I ordered 13 pin connectors (male and female)from Buxcomm.com, switch and Relay from the local radioshack and I also looked at the link below for the wiring.
https://forums.audiworld.com/audio/msgs/1166.phtml
I'm trying to keep is as clean as possible.
how hard is it to remove the CD changer in the coupe?
Thanks.
FastAssS4
Sep 13, 2005 03:13 PM
gateway
Feb 28, 2004 05:37 AM
PaulW
10
Aug 10, 2003 08:01 PM
Feraca
Audi allroad
Nov 13, 2002 01:30 PM
