Spacers: understeer, size, and results
Old Apr 13, 2004 | 07:42 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Spacers: understeer, size, and results
- About to get new wheels, and may go for spacers to get them outboard a bit.
- Why do some of us use different F/R spacers? Larger R spacers move the car towards understeer, and I'm not aware that the TT has notorious oversteer I need to correct.
- What size seems best-suited to moving a 42mm offset wheel outboard 'flush' with the lip of the wheel arch (Yes, I'll check jounce clearance)? 15mm, 25mm, yadayada?
- whose attach best, are hub-centric, and either anodized or cad? Does anode/cad matter? Sources?
TIA
Old Apr 13, 2004 | 08:19 AM
BlkTT's Avatar
New Member
Default Re: Spacers: understeer, size, and results
My wheels are 17X8 Rondells with 35mm off set, I went with 15F Spacers, 25R Spacers from H&R and also have Eibach and Koni Sports. I don't feel the endersteer and the care handles great. No rubbing and the car looks so much better with the wheels flush with fenderwells.
Old Apr 13, 2004 | 11:20 AM
Quattrings's Avatar
Default 42mm will hit the rear calipers. You need to get the overall offset down to
between 20mm and 25mm. 20mm spacers would drop that to a 22mm offset and look perfect.
Old Apr 13, 2004 | 04:41 PM
Sheep's Avatar
Default I've got 18x8.5's, no spacers but wheels are ET22 and made specific for the TT-->
You'd need at least 20mm spacers on the 42's assuming you have same width. As per pic below, you can see they're just tad inside lip.
Old Apr 24, 2004 | 12:33 PM
InTTruder's Avatar
Default Getting 15mm H&R-
Should make total offset 30mm.
The TSW 42 ET actually clear everything but just barely. besides, I wanted to move the track back out.
THANKS for the advice!
itzk15h3n
Jun 2, 2014 09:31 PM
jlive1980
A4 (B7 Platform) Discussion
Aug 2, 2006 05:46 PM
spaceboy
Jun 18, 2005 07:25 AM
coasTTal
11
Nov 13, 2004 11:59 AM
$teady$upreme
Apr 23, 2003 09:24 PM
