Would you smart guys help me with a brake problem.
Old Jun 14, 2004 | 01:15 PM
WebinaTTor's Avatar
Junior Member
Default Would you smart guys help me with a brake problem.
TT is working fine, but today the Jeep has brake issues. Each time you push the pedal it goes down farther. First time you push it, it does fine...then second push, weaker, third push even weaker.
Don't appear to be leaking fluid. Fluid level looks ok.
? Thanks
Mike
Old Jun 14, 2004 | 01:16 PM
hoTTub's Avatar
Member
busticated brake booster / master cylinder?
Old Jun 14, 2004 | 01:19 PM
TTapsale's Avatar
If your not losing fluid my guess is it needs to be bled.
Old Jun 14, 2004 | 01:40 PM
WebinaTTor's Avatar
Junior Member
Default When I push the peddle down it makes a whooshing airlike sound.
Does that help any?
Old Jun 14, 2004 | 01:42 PM
JustJeff's Avatar
...with a vacuum-assist leak
Old Jun 14, 2004 | 03:50 PM
WebinaTTor's Avatar
Junior Member
Default Last question about the brakes, I may have done the following...
If last week I topped off the brake fluid, but didn't get the cap on right, (the seal inside the cap, rather didn't seat right) then I could have gotten air in the system and bleeding it might fix, right? (Hope)
Old Jun 14, 2004 | 04:16 PM
JustJeff's Avatar
Sorry, no, it doesn't work that way
ptbo
Sep 22, 2007 04:04 PM
BrainToaster
Q7 MK 1 Discussion
Mar 22, 2007 07:23 AM
BALTS4
Feb 25, 2007 01:56 PM
tuneda4
16
Dec 4, 2006 07:56 PM
Obli
Jan 5, 2002 09:02 AM
