@ what mileage? Timing Belt/Water Pump?
Old Jun 15, 2004 | 12:04 PM
iluvTTs's Avatar
Default @ what mileage? Timing Belt/Water Pump?
After looking through the manual I was unable to find information on the timing belt for TT engines (surprising). It only provides info regarding V6 not the 4 cl/5V. Anyways, can anyone recommend when (mileage) its a good time to change your timing belt on this car? Thanks
-=iLuvTTs=-
Old Jun 15, 2004 | 12:06 PM
john s's Avatar
Member
120K miles, but you better check belt tension often, mine was slack at 70K.
Old Jun 15, 2004 | 12:07 PM
jonchavez's Avatar
Member
60K. Handbook says 105K, but totally wrong. Analysis shows breakage at around 60.
Old Jun 15, 2004 | 12:09 PM
fredfromny's Avatar
Default Manual says between 105K and 120K. Past history says...
60K modded 75K stock. Good luck!
Old Jun 15, 2004 | 12:10 PM
RafaTT's Avatar
Default It's not only a mileage thing, it's also aging of the components
Did mine at 43K, belt was stretched enough as to be lose and the water pump impeller was cracked. Car is a 2000 TTQC.
Old Jun 15, 2004 | 12:11 PM
jonchavez's Avatar
Member
Default Don't count on it lasting past 60K. Great if it does, but unless...>>>
you have an extended warranty that covers damage incurred by a snap of the timing belt, it's gonna' be a very expensive chance move to wait.
Old Jun 15, 2004 | 12:13 PM
iluvTTs's Avatar
Default Re: @ what mileage? Timing Belt/Water Pump?
currently the car has 56K, so I should get that done soon here. Thanks guys
-=iLuvTTs=-
Old Jun 15, 2004 | 12:17 PM
jonchavez's Avatar
Member
Depending on how you drive, think about it at around 60K.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 15, 2004 | 12:25 PM
YosemyTT's Avatar
Default I did mine at 60k
engine is running much better since. It idles better and runs more smoothly. I'm very happy I did this before driving 4k miles to get to TTE and back. Don't wait past 60k if you can avoid it. Be warned though, the install is a total PIA and you will need plenty of tools to do it right. I used all Audi parts apart from the water pump which I got from ECS. They sell one with a metal impellar. This was a good choice because I saw how cheap the plastic part was when I took the old one out. Make sure you get a new tensioner since that is the main point of failure that causes the belt to slip and break.
Old Jun 15, 2004 | 12:29 PM
jonchavez's Avatar
Member
Find an independent tech. to do it. Dealer is too expensive.
