okay, if anyone has any ideas, i'd love to hear 'em.
it'll run beautifully for about an hour and a half or so, and then, all of a sudden, it'll go into soft limp mode. generally, i'll pull a 'too lean' code off of the computer, but it's obvious by the black build-up on my tail pipes and my hateful fuel economy that it's running way too rich.
<img src="http://pictureposter.audiworld.com/37836/ttshot.jpg">
a smoke test revealed a leak to the left of my intake manifold that has since been fixed (thank you, juliem!! no, it ain't pretty, but it <b>works</b>!). the oxygen sensor has been replaced. the MAF has been replaced. the plugs have just been replaced. the oil has just been changed. a new timing belt and water pump were just installed. the battery was also replaced.
i'm going to the audi dealership here in montgomery, alabama in a few minutes. i'll be picking up a new temp sensor and a new oil cap (yes, i'm grabbing desperately at anything that MAY be the problem).
on a side note, my A/F gauge still isn't working properly.
the car runs really well when it's cool, and even when it's warm, but after it's been on the road for a while, it craps out. if i stop for a while, and then drive again, it's fine once more -- until it's hot again.
if anyone has any ideas, i'd love to hear 'em. TIA!!
So, the first question out of my friend's mouth - what chip is the car and if it goes back to stock, is the symptom reproduceable?
