TT gurus, I have a question for you.
Are you sure that you aren't hearing the cold start pump, or climate control fan? Both are known to make funny noises sometimes. The cold start pump will stop after a few minutes, like you described. After starting the car, when the engine RPMs drop from 1200 down to 850(normal idle), the cold start pump has shut off. Is this what you are refering to?
