MAF install advise desperately needed....Just purchased....
Old Jun 16, 2004 | 02:23 PM
petervan's Avatar
Member
Default MAF install advise desperately needed....Just purchased....
the VW part from ECS Tuning @ $89.00.
Any advise on install?.......re-set ECU?
Also, there is talk about removing the screens I guess for more "poop"? Is there downside to this (always a bad with a good).
Any help much appreciated!
Old Jun 16, 2004 | 02:26 PM
JustJeff's Avatar
Sure, downside of removing the screens is the "poop" will pop your turbo vanes.
Old Jun 16, 2004 | 02:28 PM
JustJeff's Avatar
Default Got tools?
I modified an existing bit in a set of Security bits...these were from a $5 set of bits. The bit is an existing 'pitchfork' type.I ground down the sides so it would fit inside the 5-sided opening, and over the pin that sticks out.
Works great.
<img src="http://ttbipes.home.comcast.net/jpgs/bit1.jpg">
<img src="http://ttbipes.home.comcast.net/jpgs/bit2.jpg">
Old Jun 16, 2004 | 02:30 PM
petervan's Avatar
Member
executive decision....screens stay
Old Jun 16, 2004 | 02:31 PM
petervan's Avatar
Member
fortunately my collection is complete w/TR6 tinkering but I'll need to biuld those. tks
Old Jun 16, 2004 | 02:33 PM
JustJeff's Avatar
At least with the stock filter. I have mine out with the K&amp;N in the TTDA
Old Jun 16, 2004 | 02:34 PM
JustJeff's Avatar
check to see if the 2 screw heads on the MAF are the '5' point security type
Old Jun 16, 2004 | 02:51 PM
TTinCT's Avatar
Rest In Peace
Ditto...smoother air flow thru TTDA helps...
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 16, 2004 | 02:58 PM
02TTK04's Avatar
Member
Security torx bit or needle nose pliers for removing the sensor.
Old Jun 16, 2004 | 04:00 PM
jtntsfr's Avatar
Junior Member
I unhooked my battery to reset the ecu, ghetto but it worked.
