2001 TT 225 Roadster Quattro
I have seen some problematic convertible tops on two of these. Wonder if this is just a coincidence or if there is a design problem with the tops (problem going down).
The only major thing to watch out for is the instrument cluster. My center readouts are fading, so I next service I will have cluster replaced. This is a known issue. Otherwise, only a few small items. Probably the best car I have owned!
The car is an absolute blast to drive. Having driven a 4Runner for the past 6 years, I never knew that a vehicle could be so responsive and quick. It's really the only thing that keeps me driving in to work every morning... well, there is that pesky thing called a paycheck... but I digress. Zipping down the freeway with the top down every morning makes the drudgery disappear and leaves me feeling like I've got it SOO much better than all the other latte-toting commuters on the 405. Like I figured out one of the secrets of life and they're still blindly stumbling around for it.
It's going to be a used car, so take all the usual precautions, including:
- Have it checked out by a good mechanic that's familiar with these cars.
- Try to buy one that has some time left on the warranty if possible.
- Make sure you have some money set aside to spend on upgrades. It's really, really addictive.
- Replace the suspension (shocks & springs) as soon as you can. Mine was on the original setup, and the shocks were completely shot. It dramatically improved the ride.
Oh, almost forgot -- there's one major downside to my TT. I didn't find out about it until I had driven it for a while:
It turns heads ALL the time.
40(ish) year old male heads to be precise. The thing is a middle aged man MAGNET! I'm constantly catching guys checking it out; often with a bit of envy in their eyes. Don't be like one of them. Get the TT and enjoy the hell out of it.
2. Bad fuel sending units
3. Battery replaced
4. Door/top adjustments (for creaking)
5. HID ballast
6. Driver's side seat frame (clicking noise)
7. DV (twice) finally installed Forge DV
Also had the following changed but was not required because the dealer swapped the units under warranty but they were not defective.
5. O2 sensor
6. Instrument cluster
Overall I consider it to be an average amount of problems but the car is beautiful, fun to drive and exclusive. Couldn't be happier.
Thanks for any help on how to convince Service Mgr to replace!
