High-altitude (5000+) peeps w/boost gauge>> need info from you
Old Jun 17, 2004 | 12:59 PM
BluHeaven's Avatar
Default High-altitude (5000+) peeps w/boost gauge>> need info from you
got my awe gauge installed and want to compare vac readings at idle in nuetral with ac on and off.
mine with ac off
<img src="http://users.sisna.com/Rave_nGTI/idle.jpg">
<img src="http://users.sisna.com/Rave_nGTI/idleacon.jpg">
I know I won't pull as much vac at elevation as compared to sealevel... but I remember the GTI pulling alot more vac than this!
are your readings similar or do I have a vac leak somewhere???
TIA!
Old Jun 17, 2004 | 01:55 PM
ottomann's Avatar
New Member
Default Got leak?
My gage read about the same, until I replaced a torn DV diaphram. I'm not as high as you but pull about 25+ in at idle.
Old Jun 17, 2004 | 02:28 PM
BluHeaven's Avatar
what elevation are you at though?
Old Jun 17, 2004 | 03:38 PM
emule's Avatar
Default Re: High-altitude (5000+) peeps w/boost gauge>> need info from you
I live about 150 mi. East of you in the Jemez mtns. It's cool enough here 8,000-9,500 ft. that I don't usually use the AC on my commute. So I turned it on coming home today. My car, which is identical to yours (2003 225 hp QC) idles at 15 in.Hg and went down to 10.5 in Hg at idle with the AC on. This was at my house at 8,000 ft. Readings were from AWE vent gauge like in your pictures. You don't have a vacuum leak.
My 'test range' where I log measurement blocks using VAG-COM in the morning on the way to work is an uphill straight away at 9,500 ft. It's like I'm testing the engine in a Mooney (single engine aircraft).
I've been reading a lot of the info here over the last few months and have installed a lot of the mods mentioned. Thanks everybody - This was the first time I thought I could help with some original info.
Old Jun 17, 2004 | 03:46 PM
BluHeaven's Avatar
wow thanks emule! that makes me feel better nice to see another NM TTer too =P
RSS
Feb 5, 2007 02:08 PM
VelocityS4
Oct 22, 2005 07:12 AM
TJHUB
May 10, 2005 07:54 PM
BluHeaven
Rocky Mountain Discussion
Jun 20, 2004 04:16 PM
Justin517
Apr 13, 2004 12:16 PM
