AWE gauge/pod installed :)
Old Jun 17, 2004 | 01:14 PM
BluHeaven's Avatar
Default AWE gauge/pod installed :)
<img src="http://users.sisna.com/Rave_nGTI/awe.jpg">
<img src="http://users.sisna.com/Rave_nGTI/idle.jpg">
initial test drive saw peaks of 22psi. Mostly it would peak and then drop to about 17 where it would bleed down to about 13-14 psi right before the shift. It won't actually hold anywhere for any length of time but I never stayed in it long enough for it because it was either always time to shift or I had got going too fast. So I'm not sure if I've got a leak somewhere or if its my driving lol. I'll have to get out on the highway where I can wind it out.
Old Jun 17, 2004 | 01:17 PM
IronMike's Avatar
25 Year Member
That's sweet, but what do you do when the left side of your body needs cooling or warming?
Old Jun 17, 2004 | 01:21 PM
JustJeff's Avatar
Look closely at the 2nd pic. There are slots there for the air. Maybe not as good as orig., but some
Old Jun 17, 2004 | 01:22 PM
TTyed's Avatar
New Member
Default You have a stock N75
This looks right. I am using a Audi 100Q N75 and peak at 25 PSI and dropping back to same. Some have used a manual boost controller (mine is on order), combined with stock N75 to get boost up to 25 PSI with sustained boost in the 20-23 PSI range. I am not sure how safe this is using such high sustained boost. One of my friends has it in his car, but I haven't got a chance to drive it to see what difference it makes.
RoberTT-WWCD's Avatar
Looks great Dani. How long on the install? Also next mod...Boost Machine.
Old Jun 17, 2004 | 01:28 PM
BluHeaven's Avatar
Default I don't remember! lol
maybe hour and half-two hours? but I took photos, then the neighboor had to stop and ask what I 'tore up' (lol) and I had to explain to him what I was doing (to which he asked 'why are you doing that?), then I sliced my finger open while cutting a hole in the grommet for the boost hose and had to take care of that, then I couldnt get the @#$@#$! lower dash back on (that took the longest)
On a scale of 1 to 5 with 5 being the easiest and 1 the hardest I'd rate it a 3.5, but only because of the lower dash.. its a real bear!
Old Jun 17, 2004 | 01:29 PM
BluHeaven's Avatar
Default yup... I've been getting used to it before hand by
having that vent partially closed and pointed straight ahead instead of on me. We've had several mid 90* days and it hasnt bothered me any
Old Jun 17, 2004 | 01:34 PM
Default Yeah I installed 2 at TTE and the 2nd one went right in...>>
1st one took several minutes.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 17, 2004 | 01:41 PM
IronMike's Avatar
25 Year Member
Default Ugh. Be careful when doing stuff to not cut up your hands.
I've seen way too many people slice right through tendons with screwdrivers or utility knives. Pain in the *** when it happens.... I hate the look on the person's face when I tell them I'm going to make the cut LONGER and hunt around for the other end of their tendon.
Old Jun 17, 2004 | 02:05 PM
blackfnTTruck's Avatar
Nice, That's my next big purchase.
