How do I remove the center caps from my 17" 5 spokes?
Old Nov 6, 2004 | 05:07 PM
BTTI's Avatar
Senior Member
Old Nov 6, 2004 | 05:08 PM
blackfnTTruck's Avatar
Take the wheel off and it will push out from the inside.
Old Nov 6, 2004 | 05:26 PM
BTTI's Avatar
Senior Member
I gotta take the wheel off?!? Crap... And thanks...
Old Nov 6, 2004 | 05:31 PM
kodeTT's Avatar
Elder Member
Default unfortunately, unless you want to mar the surface of the wheels or caps.
easiest to push them out...plus, it makes it difficult to steal.
Old Nov 6, 2004 | 05:33 PM
BTTI's Avatar
Senior Member
hmm...good point...
Old Nov 6, 2004 | 05:43 PM
BTTI's Avatar
Senior Member
In that case...where is the best place underneath to jack up the car?
Old Nov 6, 2004 | 06:45 PM
TTapsale's Avatar
Default I jack from here. The rubber donuts are OK but mine are collapsing.
<center><img src="http://pictureposter.audiworld.com/24828/jak_1.jpg"></center><p>...on the pinched metal that protrudes out &amp; no further back than that.
Old Nov 6, 2004 | 06:48 PM
TTapsale's Avatar
Default Another...not on the rocker panel...it's soft & will collapse!
<center><img src="http://pictureposter.audiworld.com/24828/jak2.jpg"></center><p>
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 6, 2004 | 06:51 PM
mowog's Avatar
Default with the wheel off tap out the center cap from the back of the wheel but DON'T tap it by the center-
tap it around the circumference where the steel spring part is. The alluminum center is attached to a steel clip which is a round plate with a hole in the center and 3 or 4 (don't feel like running down to garage to look at my broken one) spring clips bent off of it that attach inside the wheel. If you tap the center where the hole is and not on the steel plate you can knock the cap off the backing plate and then your're paying over $30 for a new one. Once you see it you'll know what I'm talking about.
Old Nov 6, 2004 | 07:43 PM
BTTI's Avatar
Senior Member
Thanks! I have new ones...that's why I want the old ones off...
