Just got back from QuattroFest
Old Nov 7, 2004 | 04:14 PM
KingBC's Avatar
Junior Member
Default Just got back from QuattroFest
at PIR. What a blast! It was the first time I had taken my car out on the track, any car for that matter. I am addicted now, this is worse than crack (I'm told ) I can't wait for the next event there in February.
Now need new tires , coil-overs, FMIC and last but not least a better shifter! The stocker is too loose. Any testimonials on the new DG ultra would be great.
Old Nov 7, 2004 | 05:02 PM
KingBC's Avatar
Junior Member
Default Should I go B&M or Diesel Geek?
I want a more precise, shorter throw and would prefer a shorter height.
Old Nov 7, 2004 | 05:06 PM
kodeTT's Avatar
Elder Member
Default Diesel Geek. Easier to install. You'll get a shorter height if you changed shift *****.
although I tend to think my friend's B&M was much shorter in height.
Old Nov 7, 2004 | 05:08 PM
nverfollow's Avatar
Default some of us have done both
i like the combo, b&m is a pita to install
Old Nov 7, 2004 | 05:26 PM
KingBC's Avatar
Junior Member
Any issues with just cutting/re-threading the stock shaft?
Old Nov 7, 2004 | 05:48 PM
nverfollow's Avatar
Default if i remember correctly...
the problem was getting it actually installed, there was a ball that had to go thru a tight squeeze and it took a while, dg was one of the easiest installs possible
Old Nov 7, 2004 | 10:17 PM
That damn Dan's Avatar
Poly dogbone bushings with help with the slop too..and they're cheap.
Zippy:: breaks sh*t
Mid Atlantic Discussion
Jan 29, 2008 04:20 PM
CowboysRock
Oct 9, 2004 07:26 AM
Pre95
Jul 1, 2004 05:28 PM
Niko_F
Nov 25, 2002 06:21 AM
turboawd
Mar 7, 2002 06:53 PM
