I've lost my boost :(
17536 Long Term Fuel Trim Mult System too lean Bank 1, 35-00.
It felt like when my bosch DV died so my Forge was popped open and serviced, no change. I also found <a href="https://forums.audiworld.com/tt/msgs/316887.phtml">this thread</a> and sure enough the second field is 21.9% so I think I've got a bad MAF. I unplugged the MAF and drove it around the block and still no change so I think I have a bad MAF and a boost leak. I can hear the turbo spool at around 3k rpm but seems like all the boost is going somewhere else. No visible tears or cracks in any of the vacuum hoses topside. Anywhere specific I should look?
I've got about 54k miles and the car is chipped (OCT), has a TTDA, Forge DV and APR exhaust. Any ideas would be greatly appreciated... I miss my boosht
conclusion: dirty MAF
It was causing it the read the air/fuel differently...giving me even more psi boost...thus going into limp mode.
Unplugged the MAF, cleared the codes and the car is back in its happy place. So should I run with no MAF until I get a replacement or should I run with no boost?
