I know that you use CRC electronics cleaner to clean the MAF, but do you have to take it apart?
Old Nov 8, 2004 | 05:24 AM
TTALMS's Avatar
Old Nov 8, 2004 | 05:27 AM
TTinCT's Avatar
Rest In Peace
It would probably be best, but not necessary.
Old Nov 8, 2004 | 05:38 AM
02TTK04's Avatar
Member
Also make sure that it is "no residue"cleaner. Very important.
Old Nov 8, 2004 | 05:42 AM
TTALMS's Avatar
Default Thanks. But after I pull the MAF out of the BAMM, how do I take it apart? ->>
Or do I just pull it out of the BAMM and spray the entire thing?
Old Nov 8, 2004 | 05:46 AM
kodeTT's Avatar
Elder Member
Default don't take the MAF apart, just soak spray it...making sure it is completely drenched,
then shake dry it and if possible, use a heat gun or hair dryer to make sure it is completely dried. Then, simply put it back in and it should be good to go.
Old Nov 8, 2004 | 05:47 AM
TTinCT's Avatar
Rest In Peace
Exactly....
Old Nov 8, 2004 | 05:49 AM
TTALMS's Avatar
Thanks, guys.
Old Nov 8, 2004 | 06:00 AM
HoTTrod's Avatar
has anyone posted pics of the MAF removal/cleaning process?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 8, 2004 | 06:06 AM
TTALMS's Avatar
I did a search before starting this thread, and was unable to find any.
Old Nov 8, 2004 | 06:15 AM
kodeTT's Avatar
Elder Member
Default removal is to unplug MAF connection, unscrew the two tamper-proof screws holding it,
and the MAF should just pull out. Soak spray the MAF where the air goes into the square holes (where you can see the metal sensors)...shake dry it and use a hair dryer or heat gun to make sure it is completely dried.
no pics or other guide required. typically a simple process.
