Weird Noise in cockpit.. like running water in A.C what do you think
Old Nov 8, 2004 | 11:55 AM
aTTention's Avatar
New Member
Default Weird Noise in cockpit.. like running water in A.C what do you think
I have weird noises that came up in the last year.
The weirdest one is that A.C. like noise that sounds like running water in the refrigiration tubing. A 'gurgle' type of noise.
And of course it is happening without the A.C. on but regular climate control (even by 0c).
The second one is a fan noise coming from the Climate control. I already had it replaced once and it seems to creep up on me again.
This TT sure rattles a lot for a 1.5 year old car, and don't get me started on the privacy shelf that seems to have a rattling feature built-in...
Old Nov 8, 2004 | 12:04 PM
CheeseHead Cubs Fan's Avatar
Loose the Privacy Shelf, it does nothing but cause horrible rattling (thanks HackThs)
Old Nov 8, 2004 | 12:27 PM
RafaTT's Avatar
Default The "water in AC "may be a clogged drain, look on pass side (on engine bay) >>
there should be a little hose /drain at the firewall, below the expansion valve (way down there) that may need to be cleaned up (run a wire through the drain to dislodge the clog). no diagrams as i don't have Bentley at work....
Hope this helps
Old Nov 8, 2004 | 12:47 PM
specialidiot's Avatar
3rd visit to stealership scheduled for rattle issues since June
Old Nov 8, 2004 | 01:36 PM
aTTention's Avatar
New Member
Thanks. I will check this drain out. Hopefully it will correct the problem.
Old Nov 8, 2004 | 02:26 PM
SparTTan's Avatar
Default Heh, my car has more rattles than Toys R Us.
Now that it is getting cold I can't identify where a rattle is coming from because there are so many.
Old Nov 8, 2004 | 02:35 PM
Maryland 2.7T's Avatar
Just turn up the radio
Old Nov 8, 2004 | 02:52 PM
Kinetic0510's Avatar
Member
2nd.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 8, 2004 | 05:10 PM
OldSchool AG's Avatar
Senior Member
Default Low temps + new Konis = more rattles than>>
my (ex) 1981 Diesel VW rabbit.
Old Nov 8, 2004 | 05:34 PM
TT twister's Avatar
Default 2 things to do w/ the shelf. Put caulk on the tabs and in the side attachments and/or
pry apart the shelf and run a bead of caulk around the inside edge.
